whats needed to install a new quadrant?
Old 04-02-2007, 06:58 PM
86 5.0L
86 5.0L's Avatar
Default whats needed to install a new quadrant?
well, I need to install a new quadrent since Im sure thats why the clutch isnt disengaging properly. My old 5.0 had a Steeda Adjustable Clutch cable, Firewall adjuster and Quadrant, when it burned the only thing I could salvage was the firewall adjuster. If I bought just the quadrent, used the factory cable and firewall adjuster, would that work? I forgot what the kit came with to install the quadrent, or is it just a slip-on thing?
86 5.0L is offline
Old 04-02-2007, 07:43 PM
mopman93
mopman93's Avatar
Default RE: whats needed to install a new quadrant?
if u just by the quadrant it comes with the quadrant and the washers and bushings taht are needed to properly space it from the arm. it also tells you where to put the cable o nthe quadrant depending on which type of adjuster ur using, but ud also have to by a firewall adjuster or adjustable cable becasue the quadrant is solid, not adjustable like the stock one.
mopman93 is offline
Old 04-02-2007, 07:50 PM
86 5.0L
86 5.0L's Avatar
I have a firewall adjuster that I saved from my old 5.0, so just the washers and spacers are needed to install a Steeda quadrabt?
86 5.0L is offline
Old 04-03-2007, 05:40 PM
86 5.0L
86 5.0L's Avatar
bump
86 5.0L is offline
Urambo Tauro
12-17-2016 03:30 PM
defarmer
08-13-2015 06:40 AM
ponyride00
08-12-2015 01:57 PM
pjrolvrz
08-10-2015 02:10 PM
pjrolvrz
08-10-2015 01:39 PM
Quick Reply: whats needed to install a new quadrant?
