Trick Flow H/C/I Package
Alright I'm working with a 95 GT 5 spd. I am planning on adding the twisted wedge top end kit for my car. I have a cai and full exhaust already with shorty headers and catless x pipe. What kind of power could I look for after tuning?
RE: Trick Flow H/C/I Package
Your out of your mind! I would guess 270-290rwhp... thats usually what people get out of these kits. 92whitelightening...if you are referring to rwhp you are WAAAAAY off. Also, do a search man. This quetsion has been asked a thousand times in the past 6 months... and yes I am being serious.
Mod list:
Rebuilt 306 w/stock rods and crank
10:1 TFS specific pistons
TFS TW Heads
TFS Stage 1 cam
1.7rr's
GT-40 Intake with 3/8 spacer
BBK FPR
BBK 190lph fuel pump
24# injectors with fenderwell CAI ,76mm C&L meter, and tru-flow pipe
70mm T-body and EGR (BBK)
MSD TFI coil
Underdrive pullies
BBK ceramic shorties
BBK catless X-pipe
2.5" Flowmaster catback
G-Force T-5
Mcleod clutch w/ king cobra pressure plate
True-Trac posi and 3.55 gears
Flex-a-lite electric fan
TFS TW Heads
TFS Stage 1 cam
1.7rr's
BBK FPR
MSD TFI coil
Underdrive pullies
BBK catless X-pipe
G-Force T-5
You obviously no nothing about a small block ford. Adding a small streetable cam with decent heads and an intake arent going to net you 130-140rwhp to reach 350rwhp out of a 302. It has already been said a million times that most people see 275-290ish hp with that combo. A local guy here with 94gt did the Trick Flow kit with trackheat intake and made 315rwhp which is the most I have seen from it.
I have the Trick Flow cam that comes in that package with AFR165s and the Edelbrock intake and it makes 305 and 340...I was going to sell those parts and just buy the Trick Flow package, but now I am very glad I did not. That is on a conservative tune so I could see a bit more, but I am more than stoked with the results.
ORIGINAL: 92whitelightning
I find that very hard to believe that u would only get a 70hp increase with a H/C/I swap unless that trick flow stuff is some very poor crafted ****
