how do i remove this (pics)
there are bolts on it but they are different from other bolts. i was wondering if i needa special tool to take them offor can i just use a rachet. my manual is unclear
[IMG]local://upfiles/49575/A6564288ADAF42CEBE56098FC16371A9.jpg[/IMG]
RE: how do i remove this (pics)
If you don't have a flywheel tool you will need to put a socket on the harmonica and hold it in order to loosen the bolts.That is, if you are talking about the flywheel.
Impacts are good. If you still have the dowel pins in there you can lay a screwdriver on em and stick the blade between the teeth of the flywheel Get some leverage that way, that's what I do and it works fine
A quick jerk or two on a 2' breaker bar (with a cheater pipe if nessecary) is a good poor man's alternative for the impact gun. Just have a friend or someone hold the socket against the bolt so it doesn't try to jump off when you yank on it.
jwog666
12-27-2021 08:09 PM
