questions!!!! help... engine is out of the car now...
RE: questions!!!! help... engine is out of the car now...
Chiltons FTW. A clutch alignment tool, so far as I remember, was $2.38.. When you put the clutch back on, get it on there loosely, stick the tool in, and tighten the bolts the rest of the way. MAKE SURE the tool is in there straight when you do this.
ORIGINAL: Li0nHart
you cna use a piece of broom handle in a pinch if you do not have an alignment tool....you can also make one out of an input shaft of an old tranny if you have one laying around.
ORIGINAL: LTnone
+ a bunch on the alignment tool, you'll be sowwy if you dont get er in there centered. btw, now is a good time to inspect that clutch and replace if it needs it.
ORIGINAL: my77stang
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
HIS S-197
08-10-2015 05:47 PM
