boost on a stock, high mile 5.0
RE: boost on a stock, high mile 5.0
read about a guy this something like 16# of boost on a BONe stock motor and he was only getting like 12# of air threw the stock intake and heads...... so i would say if your staying stock then stick with no more then 10-12psi anything more would just be a waste.
ORIGINAL: HC_CrAzYHoRsE
i'm confused, you're talking about a stock-as-a-rock-302?
or asking about your car? you put down a tad over 300rwhp with your H/C/I if i remember correctly? so it's already running over 50% more power to the wheels than a bone stock 302.
I don't understand why I'm being told to cut if off at 12#'s by the builder and the tuner if I ever decided to do that. My car sans forgery is loaded for bear, baby! If Pro's running 12, I feel I could run 14-16, eh?
It's moot, because I'm trying to sell the car. But let's say I for some strange reason can't sell the Horse for what I need. I'm not going to give it away because of all the money/parts and work I, Acer, Spec, et al have put in it. The new Mach is nice and all, but I'm in a MUCH better way money-wise there, and selling it and keeping the Horse ain't the worst thing I can think of. I might could move the Mach pretty easily and might even trip up and make some money on it since I bought it so cheap. If I did happen to make a little scratch and made enough of it, odds are the Horse would see boost. Just thinking ahead by asking the second set of questions..
Most of this relates to what a stock 302 could handle, which I do not have... [8D]
The stock intake/heads combo can only flow so much air. My car for instance. I have a 14# pulley on it but b/c of the restricted heads, I only see 12psi. Now, you can put a smaller pulley on and see boost quicker, (which is what I did) but it will only flow so much. Just b/c you wanna run 16#'s of boost, doesn't mean the motor is capable of it!!
Pro, I don't necessarily WANT to run 16#'s of boost.
Hell, I WANT to sell the car so I can mod the **** outta the Mach and get it to the low 12's high11's. But I digress...
I still don't have an answer to these questions, I don't think:
How much boost can a stock 5.0 stand up to?
If a guy was running 16#'s of boost on a stock 5.0, first off, how'd he get away with it or did he since he kicked some headgaskets, secondly, if he did get away with it why couldn't I with my B&P'd, reconditioned, ARP stud and bolt havin bottom end, andset-up-for-boost/spray piston-to-wall clearance?[&:]
theres no way to tell. im sure pro50sc has changed his head gaskets. theres just no saying. you could blow your motor or gaskets with 6psi. its different for everymotor. but as pro50sc said he is running 16# of boost and only seeing 12. so regardless your heads and intake and...... can only alow 12# of boost to go threw
if your just asking what a reliable amount of boost you can run is then the answer is still kinda hazy. the block can still only hold about 500ish hp.so whether you make that with 8lbs or 14lbs you cant really go much higher than what the block can hold for to long. like its been said, pro is runnin a 14lb pulley and only seeing 12 lbs of boost on a basically "stone-as-a-rock" 302 just because the rest of the engine components cant flow that well. im sure if you can run 12-14 lbs and be OK but you also have to remember that it takes power to make power with a supercharger. your car could make 400 to the wheels and have more strain on it then a car with almost 500 to the wheels and thats where reliable and dependable comes in. example: a car makes the said 400rwhp take the drivetrain loss and add that in there and then you also have to think how hard the engine is workin to turn the blower to make that kinda boost. but to give you a number, 12-14 would b the max (this is my opinion) on a bone stock 5.0 that has been refreshed as yours and dont plan on adding to many more go fast parts. after that poin you will prolly in the "red zone" for the stock block
ORIGINAL: cassidymustang
