im looking to put in a set of 3.73's ive had for a while now, thing is I have an offbrand of 3.55's in there now so the shim setup is completely different, so I would like to know what the factory pinion shim is along with the left and right sides of the carrier if anyone knows. I know this may not be dead on but it'll give me a better starting point than what is in there now... thank you
according to my tranny teacher if you go from stock gears to a good quality aftermarket gear the stock shims will be close enough to not harm anything, but this was also with rebuilding the stock diff with more clutch dics than normal and then adding .1 to each side.. but the added width was only to make the stock diff. grab harder to eliminate the right turn one wheel peels..... i can explain this better if that doesn't make sence
