carburated 5.0
RE: carburated 5.0
lower intake, carburator, fuel line from existing fuel lines to carb., non TFI dist, aftermarket ignition, fuel pressure regulator.... in line fuel pump. Some use stock fuel pumpand wire it to run all the time. i wouldnt though, ....
RE: carburated 5.0
ORIGINAL: mustangfxbdy
lower intake, carburator, fuel line from existing fuel lines to carb., non TFI dist, aftermarket ignition, fuel pressure regulator.... in line fuel. Some use stock fuel pumpand wire it to run all the time. i wouldnt though, ....
RE: carburated 5.0
A napa remaned 85 mustang 5 speed distributer. Cost about $110 before you return a core. I used a msd 6al for a iginition box. Don't use stock fuel pump, it puts out way to much pressure a carb regulator won't be able to keep the pressure down. Granetelli, Paxton, and one other company can't remember who all have pickups for external pumps for efi tanks. I used granetelli and it worked fine. I ran a holley blue pump.
RE: carburated 5.0
$177.00 for a mallory dizzy, coil, ignition module. two wires to hook up the whole deal. one 12v + and one tach wire. super simple gm style but for fords.
http://store.summitracing.com/partde...p;autoview=sku
proform makes one too for 188.00 that says it has a gear for a roller cam, the mallory didnt say so you'd have to ask - i'd take the mallory over a proform (proform is kinda generic)
RE: carburated 5.0
I have a question about that HEI, with that tach, will it work with "ANY" tach? I bought a diff brand hei, then found out that it will only work with 1974+ tachs and my stang is a 71... errrr -Jon
