efi or carb for a stroker
RE: efi or carb for a stroker
I'd personally go with whatever came stock. A carb would be cheaper / easier and way cheaper in the longrun - but you can't beat the drivability and the few extra hp of a well tuned efi setup.
You can slap a carb on there and tune iit and me done.... but personally i LOVE EFI! you geyt more power, driveability and MPG. you can get chips burned for them. you can get a PMS and tune 1000 mopre things that u can with a carb, without even popping the hood.
you need a manifold, a carb, different fuel pump, different dist, different ignition just afew of things needed
ORIGINAL: bobby
but cost wise its alot cheaper to purchase the odds and ends for a carb setup vs larger sized throttle body, aftermarket upper / lower intakes anyways, injectors, mass air meter, bigger fuel pump anyways, chip for ecu
Not only that if you upgrade power at a later date you'd likely have to go purchase, again, a larger throttle body, biger fuel pump, larger injectors, another mass air meter...
for a carb, simple new jets or a larger unit and your done.
the costs depends upon what you have to start with and what your final goal is. if you already have EFI, than why change to a carb and give up the reliablity and tunability of EFI for the age old problems associated with a carburetor such as chokes, floats, power valves, etc. to me the advantages of EFI in everyday driving far outweighs the lower initial costs of going with a carb. I would consider going with a carb only if the engine was for flat out racing and nothing else and even then I would be hard pressed to not go with EFI.
ive recently dida efi to carb 408 stroker setup, to begain it sound easy, fast and cheap not exactly true. no matter what you choose if you want good equipment is going to cost. my carb setup from fuel cell to intake manifold including Dis.,ignition, throttle cable was a litttle over 2500.00. im looking for 800hp, not a street car. to run 800hp with EFI would have been close to the same for equip. and another 1000.00 for computer programmer. If you only looking for a HP number that can be handled by a mass produce efi intake i.e. track heat, vic. jr. and so on, i would go EFI and like MD said if you want more hp at a later date youll have to do it all over again.
GOOD LUCK.
GOOD LUCK.
