Electrical Issue
#22
RE: Electrical Issue
Because when you turn it to accessory, your only drawing power from little things like the fan, and radio. A starter draws close to 200 amps, which is a lot more than anything else on the car. Thats enough draw on the battery to drain it down to nothing. Get a multimeter, set it to DC volts, and check how much voltage the battery has before cranking, and then how much while cranking, then how much after cranking. If your battery drops below 9.6v while trying to crank, your battery is shot.
#27
if your batteries fine you can try bypassing the salenoid and starting the car. when i was checking out a mustang a mechanic showed me this. put your key to the on position, but dont start the car. then pop the hood. On the right fender inside is a thingamajiggy. (in the pic). There should be like 3 prong things sticking out of it (hard to describe). and one has a boot on it. Pop the boot off and take a screwdriver and touch it on the one that had a boot on it and one of the other 2, (cant remember which one) and it will turn the engine over. (if the powers on the engine should fire right up)
[IMG]local://upfiles/37075/44F5810CBA3343A086F22F894D1A4F29.jpg[/IMG]
#29
Yeah, ford has style of starter where the solenoid isnt on the starter. That thingamajiggy is the solenoid. The one with the boot on it is the 'S' (or solenoid) terminal. Then you have a 'B' (or battery) terminal which has a constant 12v from the battery. The S terminal connects from the solenoid to the battery. When the solenoid is energized, it pulls a plunger closed and connects the B and S terminals. If you jumper from B to S and it starts, then its a solenoid problem. Thats the easiest way to test if it is a solenoid problem.
