94-95 T5 in a fox?
94-95 T5 in a fox?
will it work? i know the input shaft is longer can i change it out? how much work is required when doing this? also when i got to checkit out what do i need to look for? any more suggestions hopefully some of tranny guru's will chime in
also what else will be needed when converting from auto to 5spd?
RE: 94-95 T5 in a fox?
u have to open the tranny to change it properly, u also need the bellhousing... auto -5speed u need the pedal assy., cable, quadrent, driveshaft is questonable, i THINK the mount is the same, but's 530 and i'm half awake thats all i can think of right now
like i said today in the car you need.... trans, dual exhaust x member for your 4cyl car, pedal assembly, cluctch cable, v8 bellhousing, clutch quadrent, clutch fork,, flywheel, pilot bearing
Sidewayz6.0
02-29-2012 10:29 PM
