engines going back in..hoisting question
when i took the engine out i used the head bolt holes....now the engine is rebuilt and i need to know where i should put the bolts to hoist the engine.....im pretty sure its right here..the head bolts fits front right and left rear. is this right?
[IMG]local://upfiles/49575/EF64A4BF53C143FFBB7470C10D85D617.jpg[/IMG]
RE: engines going back in..hoisting question
I use a cylinder head accessory hole and bellhousing hole. If you have the tranny on just take one bolt out and put a longer bolt through the chain and bellhousing.
whats a cylinder head accesory bolt?
i only have the bellhousing connected to the engine so ill take a bolt out like u said...but wont it tip from side to side?
onyx are u done with your h/c/i??? im not aint got a lotta time to work on it tho... mostly just weekend and ez lil stuff after classes at nite.... this weekend i plan on making a big jump on it since i have friday and sun off.... after easter lunch im goin home and gettin to work... hoping ot get about 20 hours in this weekend on it...
i think u should be a man and just pick that block up and put it in by hand lol... no im joking... lower intake has a lotta holes on it that would work... or u have your holes on the heads... u kno on the side
ORIGINAL: CrazyCobraSpeed
ShaneB26154
35
03-04-2021 04:05 AM
HIS S-197
08-10-2015 05:47 PM
