Car sounds diff after FPR install.
Just curious what this could be from the car sounds a lot quieter than it did when i had the old regulator on it.
When i first prime the pump in the morning it almost sounds as if theres air in the fuel lines for some reason.
This is a link to a vid before the fpr and the other link is after.
It almost sounds like my pump whines more at idle and it sometimes takes two cranks to start on a cold start.
Also sounds like an exhaust leak but i don't feel one anywhere under the car.
Thanks guys
1. is the video before
2. is the vid after
3. is a vid today.
http://vids.myspace.com/index.cfm?fu...oid=2015732838
http://vids.myspace.com/index.cfm?fu...oID=2018008544
http://vids.myspace.com/index.cfm?fu...oID=2020256996
Thanks guys
2. is the vid after
3. is a vid today.
RE: Car sounds diff after FPR install.
have you done any intake mods lately? my suggestion is to get your intake and exhaust smoked at a shop. cost ya less than 1 hr labor and it will find any and all air leaks.
would bad fuel vapor lines that go from the front of the intake manifold to the charcoal canister cause this? ill go outside and take a pic to show u guys how bad they look.
http://i123.photobucket.com/albums/o...0/DSC01784.jpg
http://i123.photobucket.com/albums/o...0/DSC01788.jpg
thats wat the hose looks like hopefully i can just use standard vaccum hose to replace it.
Anyone have a vaccum diagram for the intake manifold i think i have everything hooked up right theres a line for the pressure regulator that goes into the intake manifold then theres another line that goes from the manifold to this vaccum tree where the brake booster line goes and i think theres an egr line on the left side.
