NEED HELP FAST
NEED HELP FAST
ok the motor is almost in..its bolted into the mounts and some of the holes from the bellhousing line up. the problem is the one side of the of the engine has a gap between the bellhousing..its only about a 1/4 of an inch but i cant get the motor to sit flush with the tranny....and suggestions or anything??
RE: NEED HELP FAST
what kind of trans? dowels lined up . if your sure all,s lined up tighten up a few bolts and see if the gap closes, but don,t force something if it ain't goin find what the problem is. next time trans bolts b4 mounts
RE: NEED HELP FAST
You should bolt the bellhousing up to the motor then install the tranny. Its a lot easier this way. Then when you get it to the same point youre at now have someone push teh clutch pedal and itll pop right in.
-P.
-P.
09-16-2015 07:53 PM
