A 15426378 firing order on 93'HO WTF?!
RE: A 15426378 firing order on 93'HO WTF?!
ORIGINAL: P Zero
Some aftermarket cams use the 351w firing order.
-P.
-P.
ORIGINAL: P Zero
-P.
-P.
Doh, I always get em mixed up[8D]. My first 3 302's were non HO, so I got used to all 302's having that firing order. I did have a roller cam that was the old school firing order though. I think it was made by wolverine (company no longer exists).
-P.
-P.
the engine has an extensive list of bolt ons. here we go...
Gt 40 upper and lower
gt 40 heads
COBRA computer
24 lb injectors
COBRA MAF
msd 6A or A6 i get them mixed
accell coil
70mm TB
CAI
im not sure of a cam, does not sound like it
1.7 RR SVT
gt 40 heads
COBRA computer
24 lb injectors
COBRA MAF
accell coil
70mm TB
CAI
1.7 RR SVT
vristang,
i did read that you CAN NOT just switch wires with the fuel injectors, your right. as you may recal my previous post about "modded but still gutless, why?" during that post i discovered that a z3x computer was running the show. i basically have a cobra motor.
how is a firing order switched like this. the engine looks older, ie dirt and oil seaping though. the carfax was clean and stated that it WAS a HO motor via the vin number. why and how would someone switch firing orders. from what i understang there is much more to it then just switching cams.
Like previously stated, you can't just "switch" the firing order. Most 302 components are interchangable, so all those mods could still be on a non-HO motor. That's why your car is "gutless."
You need to change the cam, dizzy, and a few other things to give it the HO firing order. I don't see how it's running at all w/an HO Cobra computer and the incorrect firing order.
Would the motor run if he actually had an HO motor, but the previous owner switched the plug wires around to the non-HO firing order? Try and switch the plugs wires around to the 13726548 firing orderand see what happens maybe. Just an idea.
