A 15426378 firing order on 93'HO WTF?!
so i was replacing my spark plugs a couple of weeks ago and noticed when i when to put the wires back on that my 1993 gt HO has a 15426378 firing order! the stock HOs have a 13726548 firing order. what in the heck does this mean? non stock cam? if so, the firing order of the injectors would have to be changed.
anyone know why someone would change the firing order on a HO stang???
RE: A 15426378 firing order on 93'HO WTF?!
ORIGINAL: jerrylee01
hmmmm wow ok thats something new to me thought all 302's had same firing order so guys which one is for the HO motor and which one is jus for stock
1 3 7 2 6 5 4 8 <-- H.O.
1 5 4 2 6 3 7 8 <-- None H.O.
ORIGINAL: vtecwho
You need to verify what computer is running the motor.
You cannot run non-HO firing order on a HO computer.
The injector firing order cannot be 'changed' by simply moving the wires, as this will switch a couple of injectors from one bank to another. Now when the computer tries to adjust AFR based on the O2 signals, things get hosed VERY quick.
Have any other mods been made to the car?
jason
