AHH wiring help needed very badly
RE: AHH wiring help needed very badly
thats the thing I have located the wire that feeds the parking lamps and its dead but I go through the rest of the switches and relays and it all works and has juice toit the only way to really get into this is to slice the harness apart again I take it?
Yes unfortunately, unless you can find the problem in an area else where, ground wire thats not connected on the motor or something like that. I'm guessing a ground wire or a fuse because none of your parking lamps work. g/l either way, btw your car looks great.
haha thanks some to you I like the 03 cobras they look good. I would accept it if it was a ground but I have no juice going outside of the cabin for it fuggg lol and the hanes manual has a wiring diagram like ou gave me and it doesnt help me because I cant decode the things and it doesnt go to the headlights it only has the engine harness itself.
I actually hate doing wiring, but I have had my share of problems, wiring can kick your ***, but with enough timme you will get it figured out. btw, did you have this problem before the new harness. If not you may need to see if the last owner jerry rigged it, just a thought.
haha Actually I didnt have this problem It was the turnsignals chasing ground everywhere and no dash lights that was the problem with the last harness. But I have made progress I have parking lights forthe BACK but still nothing in the front effing A!!
I FOUND THE PROBLEM!!!! Turns out that the headlights have a 93 harness for them and the body/ engine harness is a 89 and between those 2 years they switched the wires in the plug around and thus showing me why I have tailights but no front parking lights!! thank you tmajikman for all the help!!
Diode Dynamics
28
05-26-2022 12:02 PM
