Are these interchangeable? I've read about the SD and vacuum lines and all that. Two parts stores showed pics of Baro sensor (with the white collar), and then the parts eachhad female vacuum fittings. Is it thecorrect sensor without the white collar?
there the same thing, mass air doesnt use the vacum line and speed density does
+1...they are the same....the M in MAP means manifold and the B BAP means barametric(i think) The hose on the MAP reads manifold pressure and the hose on the BAP reads barametric pressure. SD uses a MAP and MAF uses a BAP.
