IAC Doesn't match up to my throttle body
RE: IAC Doesn't match up to my throttle body
ORIGINAL: mattdel
well, either 1 of 2 things is wrong. either the IAC is the wrong one, or the intake casting has gone awry.
can you flip it around? make the IAC go towards that coolant line. it looks like it might fit.
Mike your picutres are good. I have the same throttle body as you and I did not have this problem. It sure looks like something wrong with the casting. I would think that Summitt would give you credit on this.
ORIGINAL: onebad88
i agree with "you get what you pay for" thats why i would recommend going with bbk or some other known brand. but i can tell by te picture that it is bolted up correctly. i would return it and buy a better brand name.
ORIGINAL: CHILLERMAN
It looks like you got a factory defect, because I just installed a 70mm prof. prod. t/b polished and had no problem, my gaskets
lined right up. before this I ran a BBK and never had a problem since the get go, too bad they dont make em in polish, you should be able to get a refund or exchange
as for the guy that had thethrotle sticking problem, mine did the same thing for a while but works fine now, guess it broke in
ORIGINAL: ZachW04Stang
It looks like one of the iac bolt holes got drilled in the wrong spot. You could probably just drill a new one and tap it.
