70mm t/b on stock intake?
RE: 70mm t/b on stock intake?
ORIGINAL: SN95Stang
will the stock intake manifold accept a 70 MM t/b?.....is a prof. products throttle body any good? they are cheap so i was gunna order one....its b/t that and bbk.
ORIGINAL: PRO50SC
It will but you'll see nothing from it. Mani should be the same sized opening.
ORIGINAL: SN95Stang
u think my money wud b better spent on the suspension then? if i got a typhoon intake, t/b, and maf would that b noticeable? im gettinmg the 4.10s in this week or next week. i just want some more ***** when i get the gears...im trying to run mid 13s
if your running the stock heads then the intake, tb and egr wont add more then 15hp. i would do suspension mods first since you will be putting in 4.10s. all the hp in the world is worthless if you cant get it to the ground
yea....i hear ya..do u think that an eibach drag launch kit, 4.10s, and strange 10 way adj. shocks and struts can make me run a 13.5.....im ran a 13.99 with my 3.08 rear two weeks ago.
absolutely. you should knock off .5-.6 seconds for sure as long as the tires hook. if you dont have aftermarket control arms, might think about doing that soon. anything is better then stock. pro keeps posting a link to some upper and lower control arms for $150 which is really cheap and a great way to get more power to the ground
my parts are in my sig....yea i hav UPR solid lowers....i heard uppers dont do too much....but now i am just selling my solids and getting UPRs fully adj uppers and lowers....... think i can go 12s on just suspension with my 95 GT? i dont wanna run slicks tho.....rite now i am launching at about 4000RPMs with BFG Gforce Drag radials and there is lil spin.
