Strokers??????
RE: Strokers??????
ORIGINAL: Cleeman99
well the reason ppl say that is because the supercharger depending on what boost u go with can be usless because if u get massive mount of boost on stock block u start puching the 500hp at the fly wheel and that good for a stock 302 but u got to consider how many miles are on the car to. and u also have to if u changed ur piston see what ur comparsion ratio is.
RE: Strokers??????
ORIGINAL: ROAMING94
331 Stroker for street strip, 347 for the strip only, I've got the 331 thatwas built to be supercharged low compression. If you know your gonna suppercharge it later, I would set the motor up for it now.
RE: Strokers??????
I bought the car and the motor was just rebuilt, looking at all the reciepts, I'd say and this is including block forged crank and pistons Tfs heads about $5,000 to $6,000 thats an est. you can buy complete stroker motors ready drop in for about the same amout of money.
RE: Strokers??????
U could save your self a lot of money by using your stock block, if you did put a supercharger on it you would wanna make sure you didn't go over 500 HP thats about all a stock block will handle "so I here" never blown one up. But Dam 500HP is a fast *** street car.
RE: Strokers??????
ORIGINAL: ROAMING94
RE: Strokers??????
ORIGINAL: ROAMING94
You could build one for half of that if you wanted thats all brand new equipment
YoungStangsMan
09-05-2015 07:01 PM
95_GT_Stang
04-10-2004 04:39 PM
