Clutch goin out?
Clutch goin out?
Seems like today I noticed my car is chattering some when first starting out from a light or something from a dead stop. It also seems like when I get on it hard it makes all the noise, but doesn't seem to be goin as fast as it should for how much noise it's makin. Almost seems like the clutch is starting to slip or somethin I dunno. Any Ideas?
RE: Clutch goin out?
probably so..look at the rpms when you are flooring it, most of the time it will slip in 2nd gear or so, 1st gear in my car right now is fine and my clutch is going.
ORIGINAL: pastfast125
first try adjusting your clutch, stick your foot under the pedal and pull up till it clicks then push it back down to the floor. repeat that about 5-8 times. after doing that get on the road and put it in 3rd gear at about 2k rpm and just hammer the gas. if the rpm's just up and the car is just making a lot of noise and takes a while to catch up with itself you clutch is toast
put it in 5th, at like 45-50mph... and go from no throttle to WOT see if the rpms climb and watch the speed... youll know if its slipping or not then...
also that way to adj the clutch doenst always work, they get warn out... if it doesnt i no how to work it anyway
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
