Question about a Mustang.
#22
RE: Question about a Mustang.
If you are going to spend that kind of money on the website link you showed they also have a 1990 7-up model with supposed 65,000 miles that would probably be worth more money wouldn't it guys. And it is listed at the same price.
#24
ORIGINAL: UrSSlow
Also, I seen this car on a local board. Guy wants $5500.
1989 Mustang LX 5.0 hatchback
* 306 w/ approx 15,XXX miles
* 5 speed world class transmission
* Hurst short throw shifter
* Brand New Spec Stage 1 clutch, throwout bearing and pilot bearing
* factory sunroof
* Lumbar seats
* Intake from an Explorer
* ported e7 heads
* Edelbrock Cam
* sn95 MAF sensor
* fender well mounted CAI+cone filter
* March underdrive pulleys with a/c delete (the compressor and condensor have been removed but everything else is intact)
* 1" phenolic spacer w/ gaskets
* MSD Coil
* Steeda EGR delete
* Ford Racing plugs
* Cobra 130 amp Alternator
* New serpentine belt
* Electric fan w/ dash mounted switch
* Aluminum Driveshaft
* 3:73 posi rear end w/ 31 spline axles
* New axle seals
* Walbro 190 fuel pump
* Mac 2.5" off-road h-pipe
* Hooker 2.5" aero chambers
* Mac 2.5" chrome tail pipes (the sound is exquisite)
* New Brakes front and rear
* 5-lug conversion
* 17" polished 94 cobra wheels
* Jamex drag/lowering springs
* Mac upper and lower control arms w/ new bushings
* sub-frame connectors
* new ignition switch and lock cylinder
* New motorcraft battery
* Brand New Kumho tires
* New strange front adjustable shocks
[IMG]local://upfiles/28396/37823801AE664E31A2624638B5D6A592.jpg[/IMG]
* factory sunroof
* Lumbar seats
* ported e7 heads
* Edelbrock Cam
* sn95 MAF sensor
* MSD Coil
* Steeda EGR delete
* Ford Racing plugs
* New axle seals
* 5-lug conversion
Luke9222
10-22-2015 11:55 PM
