what size tb???
what size tb???
so i have a90 hatch with: stock bottom end, stock heads but with big valves (2.02 intake and i forget the exaust), f303 cam, trick flow track heat intake manifold, 24lb injectors, maf, fpr, cold intake, and full exaust (headers, catless h pipe, dual chamber flows).
i have the stock tb on right now, but i have a holly 75mm tb to put on. i have been reading the forums and i didn't realize that too big of a tb could hurt performance. i can return the tb, but does anyone know if i should stick with the 75mm or step it down to a 70mm.
RE: what size tb???
if for some reason you actually do lose hp it would be minimal. you might actually gain it back up top. i don't know if i would worry about it. if it will make you feel better i wouldn't go with less than a 70
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
