Plugging the smog pipe
I wanted to find out while my smog pump is on my car, should I plug the hose coming out of the pump or is it better to just put a bolt in the back of the head. btw, should I plug the two smaller vacuum hoses coming off the smog piping when I take it all off. Ever since I plugged the hose that comes off the smog pump I have this stupid popping noise and I am pretty sure it is the smog pump. Thanks in advance
RE: Plugging the smog pipe
i plugged the tube that goes to the exhaust by putting a nickel over it and welding it in solid on my father in laws gt and the next day it froze up and slung the belt. i would just get a delete kit and be done with it.
you will need the delete kit and you can still use the stock belt. if you go with the shorter belt with out the delete its prolly gonna rub between the idler pulley and the water pump.
You can just run a shorter belt. I have been doing that for over 2 years now. As for plugging the heads or tube; I plugged the tube with a 5/8 or 3/4 screw from Home Depot. (Thats been there for two years without a problem.)
ORIGINAL: CarJway
ORIGINAL: tmajikman
never mind, they are 60 to 80 bucks. thats an expensive pulley
i took all my vacum **** off my car on that smog pump where u have big hose going into pump jus put short hose in it and big bolt and hose clamp and other steel lines jus hooked them together . but can i take those lines off back heads unbolt them and what could i use to like plug the hole in the heads . and ya man i know those elemantor kits arent cheap i was gonna but 1 but im not spending that kind money jus for a damn pulley lolso if anything else ill jus leave it bolted up but its not hooked up in anyway and motor runs great dont have problems with it that way
