question on BBK adjustable clutch cable
ok it says to put the knurled portion of the adjustor ove the cable after removing the black rubber isolator... well i removed the black rubber isolator on the new cable... but i dont see how neting is supposta fit on the white plastic end that hte isolator used to be on.... ne1 who has this the help would be great... i got it form summit and i can get hte part numbers if needed
RE: question on BBK adjustable clutch cable
ORIGINAL: AdderMk2
you have to cut off the 4 small white nubs, then the firewall adjuster will slide right over it
ok sounds good... im guess u have one... did u notice a difference when u shifted?? i figured id put one in since i needed it and the engine was out so it would be much easier to get to everything... thanks for all the advice
My bbk cable made my clutch pedal a lot stiffer over a stock cable. I might try swapping it out for stock cable. I thought it would loosen up after it broke in but 4000 miles later its still just as stiff.
ORIGINAL: ZachW04Stang
Luke9222
10-22-2015 11:55 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
