4 lug bolt pattern?
4 lug bolt pattern?
whats a mustang bolt pattern, i know the newer ones are 5x4.5? well theres rims for sale here in newspaper clasified it says exactly " 2 15x10 weld draglites, 4.5" and 4.75" bolt pattern" if not mustang what kinda of car would this be for?
RE: 4 lug bolt pattern?
that means the wheel will fit two different bolt circles, one at 4.5" and a second at 4.75". to measure the bolt cirlce on a 4 lug wheel, you just measure the center to center distance between two lugs on opposite corners from each other. the way they express the lug pattern is the number of lugs first followed by the diameter of the bolt circle, i.e. 5 x 4.5 means 5 lugs on a 4.5" bolt circle.
you also need to know the backspacing and offset on a wheel to make sure it can fit on a given car too, so ask about this too before buying anything.
