Took it for a first drive
Got the tranny fluid in and the crank pulley on and took her for a spin. Shes runnin kinda rough for some reason, i hear the valves clattering, so i need to pull the covers back off and adjust em a bit. She drove pretty good tho. I also have some coolant seepin out of where the heater pipe goes into the lower intake, prolly just needs a bit of rtv. Should have all my issues figured out soon. I'll post up another exhaust clip too, she sounds much better when it was warm.
RE: Took it for a first drive
Cool!. congrats man and.. just FYI.. youre car is running rough because of the cam with the sn-95 computer. you probably already know that though. get it tuned and it should run great after that.
ORIGINAL: frdmstng1986GT
I'm takin off the valve covers and going to adjust the valves again. Hopefully i just got em too tight or too loose. Someone told me today that i need to adjust the rockers when its warm so the liftesr are expanded all the way, any truth to this ?
All I know is I just did the h/c/i swap last week and when i test drove it at higher rpm the valves were clattering so i backed off it timing to high?not nuff gas??fuel pump not big nuff??
I have almost the same setup on the same car i have crane steel rollor rockers poly locks
Ima gonna adjust the rockers agina also i went 3/4 turn then tightn them ima go 1/2 turn this time.
but i have 36 pund injectors on a stock pump so my guru sayeth when i gag it my fuel pressure is going south and im running outa fuel so i just ordered a bbk 255 and a kirbin adj reg. ill let you know if this fixes the valves there ninety five.if you solve this before i do let me know what you did lets share the info dude!!! If i get it worked out ill let you know how i fixed it
ORIGINAL: AdderMk2
what did you install for rockers? if your still running stockers, then thats not your problem
