radio harness
radio harness
well i still have my stock radio from my 93 notch four banger and want to put it in my 88 GT i have now until i get a better cd player but i need some help. i got the connectors for the 88 at the junkyard but the 93 radio has the 94 and later plugs, how can i make it work. i remember when i put in an aftermarket cd player in my 93 the small square plug wasnt used at all.
RE: radio harness
I dont see why you couldn't make it work, you just have to know which wire go to what. I just redid my S-10's stereo, and whoever had it before me had cut out the factory wiring harness all together. Not sure how it is on the mustangs, but i am sure they are all pretty much the same for the most part.
I would suggest getting a soldering iron. I just got one of them wireless "Cold Heat" ones, so i didn't have to run a cord outside. Also heat shrink tubing is highly suggested.
Pull out your factory stereo.
Black = Ground
Red = 12V Power
Yellow = Constant Power (Keeps power to the radio while the car is off)
Orange = Dimmer (not sure how it is on a car that old, but that is how it is on my 96)
All the other wires are going to be speakers. What I did was just guess off of the pairs as to which speakers wires went where, and used the process of elmination.
Have fun, and if you don't use heat shrink tubing, use electrical tape!!
Black = Ground
Red = 12V Power
Matt's 95 Stang
10-05-2015 07:16 AM
breaking
10-02-2015 01:27 PM
