Its a 5 speed.
And it is definatlly green, and when you close the door and the exhaust manifold is hot, it will spill on there and you will get steam, and a smell of coolant.
sounds like when you pulled your heater core hoses off you broke the tube on one of them at the core and its filling up your box and coming out that holr check your carpet up high on the firewall on the passenger side and see if its damp bet cha thats your prob
Yea thats no problem, im pretty sure we're talkin about the same thing, but like i said its dry. I doubt that it would dry in less than 4 hours. And i felt all around the plastic and that seemed dry too.
i will tell you that if you have colant coming from that hole and when you shut that door it comes out the air from inside is forcing it out from the heater box theres nothin else under the dash
Yea that may sound like wat it is (unfortunatly), well thank you for all of your help you just gave me i'll look into it tomarro.
Do you think i need a new heater core now?
