question bout rear end
pwer braked it little earlier and left rear wheel hopped and right wheel broke lose i let off of it and tryed again and same . what chances of something being broke in there . or maybe have splines stripped out on left axle . just wondering and if it is axle does any one know what axles my car has in them its stock 85 gt 5 speed vert. ok thanks ...
RE: question bout rear end
could be the rear. the 85's still used the wimpy 7.5 inch rear versus the 86 and up 8.8 inch rear. i would look at youre quad shocks and youre control arms and there bushings.. more then likely you have a bad quad shock on that side or a bad upper or lower control arm bushing.
yep, 86-93 will bolt right in. if you can find one from a turbo coupe bird of a svo stang then it will bolt right in too and have disk brakes in the rear. but the wheel hop is most likely caused by the quad shock or the control arm bushings. if you replace the control arms with some aftermarket ones then you can ditch the quad shocks cause the better control arms will stop the wheel hop.
nos hell no . lol prob blow motor to fast with that . super charger or turbo can you put those on a carb engine ? and my pockets say no deal on either of those right now . but h/c/i yes like to do 1 of those soon .
