Ford HD clutch keeps snapping my cable any brand cable preference???
Ford HD clutch keeps snapping my clutch cable i have tried several different ones from the parts store. Is there any aftermarket brands that yall have found to work good. thanks eric
RE: Ford HD clutch keeps snapping my cable any brand cable preference???
Stock ford cable, or the MM cable which is a stock cable lengthened 10" or so I believe. Any adjustable crap cable will snap on you because they are smaller in diamter than a stock cable. Much thinner.
First make sure your cable is as far away from the header. I snapped 2 brand new cables and then i realized the cable was too clost to the exhaust. The cable would heat up too much and then snap.
i have UPR cable i think it is pretty thick and had it for over a year now and still looks new. I took it out to lube it the other day. I also have the spec stage 2, might want to consider that
Faolan65
08-27-2015 06:40 AM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
