80mm mass air
Old 04-13-2007, 04:12 PM
house302
house302's Avatar
Default 80mm mass air
if i bought the mass air housing from an 98 cobra which is 80mm. Couldnt i just take out the mass air sensor and put it on the 80mm housing. i currently have the 70mm cobra mass air that is set for 24lbs injectors because i have the 93 cobra computer also.
house302 is offline
Old 04-13-2007, 04:18 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default RE: 80mm mass air
no
FivePointOhh is offline
Old 04-13-2007, 05:26 PM
house302
house302's Avatar
if i cant then why does c&l just sell housings, but they give you different size sample tubes and you have to use your own sensor. wouldnt that be the samething as getting a housing from a newer mustang.
house302 is offline
Old 04-13-2007, 05:31 PM
FivePointOhh
in limbo
different sized sample than what the computer is use to seeing. get it calibrated and it will work. otherwise, no it wont work just switching the sample tube with a new sensor wont work.
Old 04-13-2007, 05:52 PM
house302
house302's Avatar
my sensor and the ford factory80mm housing.
house302 is offline
Old 04-13-2007, 05:54 PM
ih8chevy
ih8chevy's Avatar
just out of curiosity, what is it ur runnin that requires a 80mm maf?
ih8chevy is offline
daltron
04-28-2016 08:10 PM
Lethaldosage423
10-19-2015 12:12 AM
Dokilar
15
10-16-2015 08:13 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
Quick Reply: 80mm mass air
