will this setup get 300-35 rwhp?
I figured that i would ask to see what some major things would get me this hp
1. 302 Blocked bored .40 over with stock style pistons.
2. Ported gt40 heads with 1.6 roller rocks
3. Gt40 upper and lower intake
4. 75mm throttle body with egr
5. 24# injectors
6. 76mm maf
7. Shorties with off road h pipe
8. Aftermarket Fuel rails
9. 3.73 gears.
10. .512 Custom ground lift cam
Would that big of a cam work with gt40 heads? i didnt know because i cant go over .510 with trick flow heads. let me know. thanks
5. 24# injectors
6. 76mm maf
9. 3.73 gears.
RE: will this setup get 300-35 rwhp?
ok. well i was told that i couldnt go over the .510 lift amoutn. chek on page 2 or 3 i posted what pistons will work for trick flow heads and one guy said he called and asked and that is what they said.
I don't see that setup breaking into the 300 HP range. Essentially just swapped the top end with a few other things.
To compare it with a similar swap.. People who install the Trickflow top end kit (H/C/I) usualyl end up with 285ish RWHP.
ORIGINAL: VigCS
You guys are seriously underestimating what you can get with GT40s. I've seen dyno sheets all over the place. Common numbers are 280ish.
