HELP PLEASE READ!!!!!!!!!!!!!!!
JUST GOT HOME FROM TRYING TO PUT IN THIS H-PIPE ALL BACK BOLTS AND FRONT PASSANGER SIDE CAME OUT FINE ONE BOLT ON THE FRONT DRIVER SIDE OF THE H-PIPE WE COULD NOT GET AT TRYED EVERYTHING COULD NOT GET AT IT STARTED CUTTING IT OFF GOT HALF WAY THREW THE PIPE AND COULD NOT GO ANY FARTHER WITH THE CUTTING WITH OUT HITTING STUFF!!!!! PLEASE HELP ANYONE HAVE TROBLE WITH THIS BEFORE? ITS A 93 GT. THANK YOU FOR HELP!~!
RE: HELP PLEASE READ!!!!!!!!!!!!!!!
I think you have your caps lock button on. Just push the button and it should fix the problem. Your problem is hard with out seeing whats up. Did you try a swivel socket?
ARE YOU HAVING TROUBLE REACHING THE BOLT OR CAN YOU REACH IT BUT ITS JUST NOT TURNING BECAUSE IT IS RUSTED BECAUSE IF IT IS JUST RUSTED THEN YOU CAN USE SOMETHING LIKE PB BLASTER TO SPRAY IT ON THERE AND LET IT SOAK AND THAT WAY IT WILL LOOSEN UP THE RUST AND THE BOLT SHOULD COME RIGHT OUT BUT IF YOU DO THAT YOU NEED TO LET IT SIT FOR A FEW HOURS OR ELSE IT WAS POINTLESS AND YOU DONT WANT TO WASTE YOUR TIME SO JUST MAKE SURE YOU SPRAY A LOT AND I MEAN A LOT!!!!!11111!! OF PB BLASTER UP TEHRE AND THEN COME BACK ABOUT AN HOUR OR TWO LATER AND TRY THE WRENCH AGAIN AND IF THAT DOESNT WORK THEN YOU MAY HAVE TO USE A DREMMEL OR SOMETHING LIKE THAT TO CUT THE BOLT THEN YOU JUST GO TO HOME DEPOT AND BUY A REPLACEMENT BOLT.
ORIGINAL: 88BlueGT
lmao hahah
Im confused... why couldnt you just wrench it off?
lmao hahah
