80mm mass air
80mm mass air
if i bought the mass air housing from an 98 cobra which is 80mm. Couldnt i just take out the mass air sensor and put it on the 80mm housing. i currently have the 70mm cobra mass air that is set for 24lbs injectors because i have the 93 cobra computer also.
RE: 80mm mass air
if i cant then why does c&l just sell housings, but they give you different size sample tubes and you have to use your own sensor. wouldnt that be the samething as getting a housing from a newer mustang.
daltron
04-28-2016 08:10 PM
