Data aquisition
Old 04-14-2007, 12:16 AM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: Data aquisition
ORIGINAL: iceman89gt
not too much if your wanting realtime data on injector duty at all rpms and speeds or if you want to change the spark advance in 500 rpm increments from 500 to 9000 or if you want to set rpm limiter higher than stock or see the air fuel ratio across the range in realtime plus much more.
apparently you have never investigated the wonders of the true stand alone EMS
AdderMk2 is offline
Old 04-14-2007, 12:20 AM
iceman89gt
iceman89gt's Avatar
what about it
iceman89gt is offline
Old 04-14-2007, 12:28 AM
AdderMk2
Banned
AdderMk2's Avatar
megasquirt does everything you just listed... and at a much more reasonable pricetag
AdderMk2 is offline
Old 04-14-2007, 12:37 AM
iceman89gt
iceman89gt's Avatar
so your saying this megasquirt is a piggy back system for a eec-iv with real time playback on all the above listed aspects at all ranges.
Old 04-14-2007, 12:38 AM
AdderMk2
Banned
AdderMk2's Avatar
no... I said its a stand alone system
AdderMk2 is offline
Old 04-14-2007, 12:51 AM
iceman89gt
iceman89gt's Avatar
its a good price but do they charge you more for software and wiring and sensors for this system. the pms is pricey but its a dashmount unit thats compact and very user friendly. not saying this one isnt. monitor each cylinder individually ,o2 sensors, set tps voltage, manipulate maf readings and voltage,control nitrous systems,and injectors at start up. oh and by the way this unit will also go into stand alone mode at 2,000 rpms.
Old 04-14-2007, 12:52 AM
94StinkinLincoln
94StinkinLincoln's Avatar
tweecer is an option if you dont want to convert to speed density.
94StinkinLincoln is offline
Old 04-14-2007, 12:56 AM
iceman89gt
iceman89gt's Avatar
why would you have to convert to speed density
Old 04-14-2007, 12:57 AM
r.barn
r.barn's Avatar
www.tweecer.com
http://autosportstyle.com/shop/ford-...m-p-47694.html
megasquirt for the electrical engineers out there.
Anderson PMS, but its kinda old school tech now, but was one of the first
I'm having the AEM system installed right now.
my tuner who is also an SCT tuner/burner, swears by them
r.barn is offline
Old 04-14-2007, 12:59 AM
iceman89gt
iceman89gt's Avatar
pms is handheld no software no laptop dashmount system
Quick Reply: Data aquisition
