Data aquisition
Data aquisition
This is a bit of rookie question. I was looking at my friends car (twin turbo stealth) and he has various turn dials which he can play with to adjust fuel ratios, timing, etc...
I was looking in summit and didn't really see anygizmos like this for 5.0s. Any of you guysuse devices like this? Anything you recommend?
RE: Data aquisition
not too much if your wanting realtime data on injector duty at all rpms and speeds or if you want to change the spark advance in 500 rpm increments from 500 to 9000 or if you want to set rpm limiter higher than stock or see the air fuel ratio across the range in realtime plus much more.
