T5 trans
#22
RE: T5 trans
ok i know tons of ppl have done AOD to T-5 swaps, all I would like to know is will the AOD crossmember work and will i have to have and special brackets or do any fabrications for the swap?
#23
RE: T5 trans
Here's a link from when I researched the swap to do in mine, since my AOD sucks. it should answer most of these questions, and includes a parts list: http://www.allfordmustangs.com/Detailed/25.shtml
#24
RE: T5 trans
ORIGINAL: 91ford302
The block plate may or may not be the same, but the bell housing is as well as the driveshaft.
You should not have to fab anything up, but will need the clutch pedal assembly fora manual. Something I've also heard/noticed is the location of the speedo cable on the AOD. It comes in thru the hole where the clutch cable will need to go, and the speedo cable needs to be moved over toward the middle [from the driver's side]to the next hole a few inches over.
#25
RE: T5 trans
ok one more question. Do have to drain the oil to take the flexplate off and put a flywheel on? Ive heard that the oil will come out through those holes in the one piece rear main seal engines.
thanks
nate
thanks
nate
#30
RE: T5 trans
another quick question since I thought of it... Is there a hole below my automatic shifter with like a cover plate or am I going to have to cut a hole in the floor of the car to get the manual shifter up through?
