Backfiring in the intake manifold
Old 04-16-2007, 02:50 AM
89TripleWhite
89TripleWhite's Avatar
Default Backfiring in the intake manifold
i am pretty sure that is where it is coming from, i had a mechanic tell me that could be the problem, but he was a tranny specialist so imnot so sure of taking his word. but anyways the popping sound only happens when my engine is ice cold and i give it gas without letting the engine warm up fully, the engine fully warm only gets to be about 160-170 degrees max, even if im flooring it all day. when the engine is cold, i start by giving it gas and it is real realsluggish, i need to put my foot down a good distance before any power can be felt, and as soon as i get past 2000-2500rpm range it all of a sudden kicks in power. the popping noise only happens when i give it gas. any ideas? i bought the car used, it has 110,000 miles, flow master cat back, msd cap and rotor with ford motorsport 9mmwires (the cap/rotor and plugs and wires i had put on 2 days ago, the sound was happening before that) and a mac cold air intake. to finish it off. the engine never backfires or pops when it is warm. any ideas would be greatly appreciated. thanks
[IMG]local://upfiles/66753/17DE18DCC15847F8875E1A72DF35D93A.jpg[/IMG]
[IMG]local://upfiles/66753/D3D448E5CD024EEDBB708A142BED9955.jpg[/IMG]
89TripleWhite is offline
Old 04-16-2007, 03:04 AM
mattdel
mattdel's Avatar
Default RE: Backfiring in the intake manifold
bad ACT or ECT
mattdel is offline
Old 04-16-2007, 03:07 AM
89TripleWhite
ok cool thanks, what do they stand for? sorry im a little slow....long day trying to figure out what this noise is
Old 04-16-2007, 03:09 AM
JZTRK
JZTRK's Avatar
You might want to check your timing
JZTRK is offline
Old 04-16-2007, 03:10 AM
89TripleWhite
my timing was at 8 degrees, and they advanced it to 12, stock is 10, and the noise was happening before that anyways....
Old 04-16-2007, 03:12 AM
mighty90
mighty90's Avatar
I like the way your car looks without the luggage rack, remind me to do that to mine when i get back.
mighty90 is offline
Old 04-16-2007, 03:13 AM
AdderMk2
Banned
AdderMk2's Avatar
timing, ect, act, THERMOSTAT... you car should reach atleast 180-190 degrees to run properly..
also check your O2 sensors
AdderMk2 is offline
Old 04-16-2007, 03:14 AM
89TripleWhite
haha yah it looks cleaner without the rack on....but looks are nothing when my engines popping.....[X(]
Old 04-16-2007, 03:18 AM
89TripleWhite
well my timing is at 12 degrees now, and it still pops, i have back O2 sensors i had it checked, thus my check engine light being on, what does ect or act stand for?
Old 04-16-2007, 03:19 AM
mighty90
mighty90's Avatar
Sounds to me like you got a sticky substance causing your lifters or valves to stick. As the engine gets hotter, it would make sense that the stuff would lose its sticky quality and free up the engine. Rather than constantly wasting your money trying to figure out what the problem is like i did, take it to a local mechanic and see what is the problem. Chances are its internal and needs a little bit of deconstruction to get to.
mighty90 is offline
Quick Reply: Backfiring in the intake manifold
