Will these heads work on stock bottom end?
RE: Will these heads work on stock bottom end?
well i know the afr 165's use a 1.9 intake and a 1.6 exhaust. and i believe either edelbrock or trick flow uses a 1.95 intake so you shouldnt have any issues there. lift and duration will effect p/v clearance tho.
Im using gt40p's myintake valve is stock but myexhuast is 1.54 stock bottom end
Im using 4.99I 5.11E 220 224 duratiion at .50lift cam nothings hitting if that helps you any??
well lets see here, i wana grab a #19 steeda cam and 1.7s...
specs on the steeda: (This is for the No,18 the 19 is supposed to have the same specs)
[ul][*] Lift .480 w/1.6 Rockers[*]Duration 220° @ 0.050 intake[*] Duration 226° @ 0.050 exhaust[*]Lobe Separation 112[/ul]Think Ill have a problem?
ORIGINAL: LCBlackDep183
Just looked up trick flow they use 2.02" Intake 1.60" Exhaust valves
Twisted Wedge heads feature an exclusive combustion chamber design.The patented 61cc chambers feature rotated intake and exhaust valves moved over the center of the cylinder bores. As a result of optimizing the valve locations, valve angles, and combustion chamber shape, the Twisted Wedge heads use stock height exhaust ports without power loss.
The heads are machined for 2.02" intake/1.60" exhaust valves to build top-end power without sacrificing bottom-end torque. They don’t require flycut pistons for use with cams up to the specifications listed—no other 2.02"-valved head for small block Ford offers these features!
It doest say anywhere in there that the design was to prevent hitting... I dunno any insight anyone?
