best cam
best cam
Currently I'm rebuilding my motor and looking to put in a good cam and having trouble on which one to go with but maybe thinking a comp cam. I plan on running around 10:1 compression, trick flow heads, full exhaust, 24# injectors with C&L 76mm MAF, 75mm tb, and performer intake. any help and suggestions are greatly appreciated. thanks
RE: best cam
ORIGINAL: Must89gt
So you would stay away from comp cams? and what is the difference between stage 1 and stage 2 sorry i am real new to this and don't know too much sorry. thanks
stage 1 and 2 is the aggressiveness of the cam:
stage 1: Good idle, strong midrange power. Aftermarket intake, heads, and headers recommended. Requires modified mass airflow.
Compression: 9:1 minimum
stage 2:Fair idle, good midrange power. 2,500-3,000 rpm stall converter or five-speed recommended.
Compression: 9.5:1 minimum
RE: best cam
I believe it is the stalker front end. It was on the car when i got it. I assume my car was at one time wrecked in the frint, because the hood and bumper are aftermarket, and the paint is new from the fenders forward. Oh well, it drives![8D]
