clutch cable help =(
i got an aftermarket quadrent and self adjuster on the firewall, i just recently snaped my old clutch cable and just got a new one...i put the new one in and the clutch is all the way at the top and part way engaged when my foot is off the clutch, what do i do....thanks for the help
RE: clutch cable help =(
but it dont matter which way i adjust it....if i contract it in twords the fire wall then the pedal is as hard as a rock and is somewhat engaged when i dont even have my foot on the pedal and if i expand it away from the firewall it gets easyer but then i cant push the pedal all the way down which is a problem cause then i cant start the car..
Steeda Clutch Quadrant?
It takes real accurate adjusting, I installed one, and adjusted it to tight, it seemed to work fine, couple days later... my throw-out bearing welded to my transmission [:'(]
There should only be one place to adjust it on the clutch arm itself under the car... Nothing you can do besides play with it and test it until it's right.
My car did that when i got it, and it was the throw out bearing and the bearing retainer.. they were both made of plactic?I changed to a steel beraing retainer and new throw out bearingfrom 50resto and changed to clutch cable and quadrent tosteeda.. and works great..
breaking
10-02-2015 01:27 PM
junior04
09-28-2015 10:53 AM
