Wheel/Tire Question
Old 04-18-2007, 01:08 AM
MadMan@TheWheel
MadMan@TheWheel's Avatar
Default Wheel/Tire Question
I am sure this has been asked about a million times. But oh well. '93 Notch rear wheel and tires. Max tire size and with what size wheel and backspacing? (btw 5lug and disk conversion)
Thank you in advance.
MadMan
MadMan@TheWheel is offline
Old 04-18-2007, 01:09 AM
89 fox
89 fox's Avatar
Default RE: Wheel/Tire Question
what size rims?
89 fox is offline
Old 04-18-2007, 01:11 AM
MadMan@TheWheel
ORIGINAL: MadMan@TheWheel
MadMan
Exactly one of the questions I am asking...the holistic approach.
Old 04-18-2007, 01:13 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
17x9, 6.0 backspace, 275/40/17. Perfect fit, quad shock removed.
PRO50SC is offline
Old 04-18-2007, 01:15 AM
MadMan@TheWheel
You are the man Pro. Thank you. You sure I cannot squeeze a 10" tire in that bitch though, axle stab shocks removed?
Old 04-18-2007, 01:17 AM
JustalittleLX
JustalittleLX's Avatar
i have 18x9 on my car with 295/35/18 and i just had to roll my fender and 180 the quad shock good luck with it though. you can run 10.5s but its kinda hard.ive seen 20s on a fox so whatever youwant to do u can. justusesome spacers if you want
JustalittleLX is offline
Old 04-18-2007, 01:20 AM
MadMan@TheWheel
Cool, thankyou. What I want really is to not have to alter the wheel wells at all. If I am going to do that I will mini tub like I have done in the past. I am crazy like that, if I have to start bending and hammering, I'm mini tubbing....lol
Old 04-18-2007, 01:22 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
You can runa 10" wheel w/ 6.5 backpacing and a 1/2 spacer. You'll also have to do a lil inner and outer fender work and can maybe get some 315's on it.
PRO50SC is offline
Old 04-18-2007, 01:30 AM
MadMan@TheWheel
Curious, the issue I know I will have running a 10", is under load, I will probably have rubbing issues w/o some serious well work. At least that's what I see when I measure it all out. It is a defining moment for me, I was trying to stick to un-modified wheel wells (i.e. no tubs) but it may be the way I go just for versatility, and getting the body a little closer to the ground. Hell time to step back and re-evaluate. As always Pro, you are a gentleman and a scholar.
Old 04-18-2007, 01:37 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
LOL thanks. I would stick w/ the original combo I listed. You may be able to get some 295's on there w/o any issues. It's def gonna be one of those trial and error things. The 275's looked good on my car and I was happy w/ them. Plus I didn't have to worry about anything rubbing or having to beat my fenderwells either.
PRO50SC is offline
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Wheel/Tire Question
