What heads and cam for an 86 GT?
Thanks to a bonus I wasn't expecting, I am ready to scrap the horrible 86 stock headsand get a cam and heads for the stang. I need some input on afew things.
Are the Trick Flow heads the only after market heads I can use without notching the pistons? (Remember, 86. Flat top pistons) What heads and cam to go with my Cobra intake and Vortech SC? I need to stay smog legal in CA. I want to keep the Cobra intake. Usage of the vehicle is street/strip. Drag races once in a while. Not a daily driver. I would like to do the work myself, but I won't try notching pistons, so if I went AFR heads and a custom grind cam (that was one recommendation I got) I would have it done at a shop (more expensive and not as much fun). Any input is appreciated. |
RE: What heads and cam for an 86 GT?
get a machine shop to notch them for you, not expensive
well let me say this after a lot of research the trick flow tw heads fit the flattops. and the cam thatis in the 86 sd cam is a good cam people have topped 300 wheel on it. i would stay wit stock and put some tw heads and be done. jmo
Thanks for the suggestion. Ihadn't considered leaving the cam stock. Have to think about that. :eek:
Stock cam is pretty good. put the twisted wedges on it.. and maybe some 1.7rr's to up the lift of the cam a little to get a lil more air in there. not posative if you will havepiston-to-valve clearence problems with the new larger valve size and the extra lift of the 1.7rr's... i know you can run them on E6 heads without a problem.
Thanks. I was also wondering if I should go with o-ring gaskets. Thouhgts?
