piston stop
Old 04-18-2007, 01:46 PM
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
Default piston stop
i need one to measure TDC so i can install my new cam properly... were is a good place to get one and do they have to be ne ceratin lenght... i know there are too kinds... heads off and heads on which is better... how are both used??
also does autozone rent-out dial indicators???
CrazyCobraSpeed is offline
Old 04-18-2007, 01:49 PM
Ninety5five0
Ninety5five0's Avatar
Default RE: piston stop
Are your heads already on ?
I didnt use anything at all to put my cam in.
Ninety5five0 is offline
Old 04-18-2007, 01:57 PM
15austin
15austin's Avatar
Just put the timing mark on the balencer to 0*. make sure it is on the compression stroke. You dont need to find TDC to install a cam, just line up the marks on the timing gears.
15austin is offline
Old 04-18-2007, 03:05 PM
CrazyCobraSpeed
ORIGINAL: Ninety5five0
heads arent on but i can put them on... im doin it cuz jay see it needs to be done... he built the cam so that it would be installed a certain way so it needs to be u kno.. im not goin to pay 350 or w.e. it is for the cam and them jus throw it in and not worry about it being rite
ORIGINAL: 15austin
considering hte balancer is off im not sure how u expect me to do that.... as for finding TDC yea i do need to so i can make sure my cam is at the correct degree so i have the proper amount of lift at TDC so the custom can is setup like it should be
cr620
10-03-2022 10:18 PM
4cylinderplus2
10-09-2020 07:45 PM
IronRaptor
09-09-2015 08:10 AM
Quick Reply: piston stop
