Nitrous Question...(noob)
Sorry this is probably a stupid question but since im almost done peicing together my wishlist for my H/C/I i figured i would start looking at stage II of my build which was a small shot of nitrous...
I was only wanting to stick a 75-100 shot in the motor however it seems that the only kits i can find availible for that size shot are dry kits? I really wanted a wet kit for the extra secuirty of not risking running lean...
If this is true i guess ill just bit the bullit and throw some 24lb injectors and new maf into the mix... I wish the cylinder head fairy would just come down and give me all the stuff i need...
RE: Nitrous Question...(noob)
wait your running 1.94 intake valves? do YOU happen to know if they will clear a stock piston without getting them flycut? im looking at a set of worked over gt-40ps with 1.94/1.54 vales and a Steeda #19 cam. and cant figure out if im going to hit or not
Im not sure on the stock pistons. I have TRWs and there is plenty of room. I put some putty on the piston to check the clearance, and the valve did not even touch the putty. I would say they woud work on the stock pistons but not 100%. sorry
