88 GT hatch rattles
88 GT hatch rattles
Alright the 88 hatch won't stop rattling, if i adjust the stricker down, i have to slam it so hard it shakes the other mustangs rattle, i don't understand why it won't stop rattling
RE: 88 GT hatch rattles
could be because the previous owner was slammin 1000 watts of bass back there, check everything. all the mounting bolts, all the hinges(for cracks and bends), check it all. make sure the latch that holds the striker isn't broken. whatever the reason is, it can be fixed, its just a matter of finding it.
I have had that problem. Here are two solutions that worked for me. First check the two bump stops. They adjust up and down are are located in the hatch area inside the car. Second, check the plastic sleeve that surrounds the striker bolt. If it is worn or broken, the latch will shake around the bolt. Hope that helps.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
