MAF i can't find a definite answer
Old 04-21-2007, 01:22 AM
CantStopTheFox...
CantStopTheFox...'s Avatar
Default RE: MAF i can't find a definite answer
ORIGINAL: 5.0stanger
ORIGINAL: enix187
What goes into a speed density-MAF conversion, please give me a straight answer
http://www.stangnet.com/tech/maf/massairconversion.html
Seems like that link is the answer
CantStopTheFox... is offline
Old 04-21-2007, 01:50 AM
5.0stanger
5.0stanger's Avatar
ORIGINAL: tmajikman
hey adder why is it a waste of time
Because he runs a stand alone, same as SD, but his is tunable.
5.0stanger is offline
Old 04-21-2007, 10:20 AM
tmajikman
tmajikman's Avatar
ORIGINAL: tmajikman
Oh yeah, he has the engineering degree to totally wire up theMega squirtcircuit board, I forgot about that, I am doing the maf conversion as soon as I get the maf sensor, I already have the computer and harness. I may need to ask you a question or two 5.0 stanger when I do mine.
tmajikman is offline
Old 04-21-2007, 10:25 AM
5.0stanger
5.0stanger's Avatar
Go ahead...I will help ya out...just hit me up with a PM
Old 04-21-2007, 10:29 AM
AdderMk2
Banned
AdderMk2's Avatar
who ever said you need a degree to do it... you can buy the damn thing pre-assembled
its really no harder than installing a stereo
AdderMk2 is offline
Old 04-21-2007, 10:31 AM
tmajikman
tmajikman's Avatar
ORIGINAL: AdderMk2
It just sounded like it was a good bit of know how to put the one you have together, and I can even solder.
Old 04-21-2007, 10:33 AM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: tmajikman
ORIGINAL: AdderMk2
long as you can solder, your all set. the only tough components to install are the transistors... but everything is laid out for you, step by step in the assembly manual
AdderMk2 is offline
Old 04-21-2007, 10:38 AM
tmajikman
tmajikman's Avatar
ORIGINAL: AdderMk2
ORIGINAL: tmajikman
ORIGINAL: AdderMk2
would the 87 computer still work, or woul it need to be swapped?
Old 04-21-2007, 10:42 AM
AdderMk2
Banned
AdderMk2's Avatar
huh?
AdderMk2 is offline
Old 04-21-2007, 10:45 AM
tmajikman
tmajikman's Avatar
ORIGINAL: AdderMk2
huh?
Do you actually remove the computer from the car and just use the new board from mega squirt?
Quick Reply: MAF i can't find a definite answer
