Which Intake? Trick Flow or GT-40?
RE: Which Intake? Trick Flow or GT-40?
hey guys, i have a gt40, i bought it because I got it and a spacer and adjustable regulator w/ gauge for $200. I really didnt notice that much diffrence when I put it on, it may be because of my crappy stock heads. Has anyone had any big gains from a GT40? Should I sell mine and get a better one. I notice Gt40 intakes on Ebay all the time for $300-400. Maybe I should sell and get a better one, what do u guys think?
i got a street heat trick flow and a 70mm bbk tb, and egr spacer.... i noticed it pull a little bit harder in the end of 2nd gear and the mid-end of 3d gear... was satisfied with it.... hopeing for alot more after i get that 76mm mass air
If I were you, I would go with the Edelbrock RPM II, they are one of the best intakes for our mustangs, but if you want power, get some aftermarket heads, GT40s are nice, but AFR's are the best. But dont get heads and then put your stock intake back on, you should do both at the same time, but it does get a little pricey, plan about 2g's.
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
