id get some kind good lubericant spray 1rst and spray sht out of them . and get anything other than wd-40 cause i dont think that stuff is worth a sht .
well, ina case like that I would use a penetrating spray not a lube. Hit the fittings withsome PB spray about an hour before you plan on working on them. If you are reusing the lines I wouldnt get any pentrating oil on the actual rubber lines themselves, only the hard drawn lines.
And WD-40 is awesome when you use it for what it was intended
